1997 front end changes from 1994?
Old Nov 20, 2006 | 08:05 PM
Guest
Default 1997 front end changes from 1994?
Alright, heres the deal. The front end of my 1994 Accord is messed up from a wreck. Front hit at about 15mph. It is definatly fixable. As for outside details: the front bumper is broke in the middle, the hood is bent back, and the front corner lights are falling out. Under the hood: Radiator is bent a little from the middle, some frame is bent in the middle of the front. So what I'm looking at it a 97 Accord EX with a blown tranny. I know there were some changes from 94 to 97, but is everything at the front end interchangable??? Plz respond Thanks...
Old Nov 20, 2006 | 08:12 PM
sir_nasty's Avatar
Default RE: 1997 front end changes from 1994?
To the best of my knowledge it shoudl interchange just fine.... However make sure you get that radiator pressure tested if you are going to continue to use it... It'd suck to get all your body work done then blow the motor due to a bad radiator....
cindjo717
Sep 10, 2007 01:17 PM
thunder_x
Sep 1, 2007 11:05 PM
robdog
Nov 7, 2006 02:59 AM
blackpearlv6
Jun 20, 2006 05:06 AM
veedubxlr8r
Dec 17, 2005 01:04 AM
