camgear Increase horsepower and torque without any cam changes?
Old Aug 31, 2007 | 01:27 PM
thunder_x's Avatar
Default camgear Increase horsepower and torque without any cam changes?
i was looking at this AEM cam gear for my car and it said "Increase horsepower and torque without any cam changes"
is this true?
has anyone tried it?
because if i can add power just by bolting on this cam gear without any tuning, then i am willing to buy it
http://www.cardomain.com/item/AEM23803B?vq_id=none
Old Aug 31, 2007 | 01:54 PM
sir_nasty's Avatar
Default RE: camgear Increase horsepower and torque without any cam changes?
On a heavily modified engine it probably will.... the only gains you'd get from it would be weight reduction, so some gains yes but minimal.
Old Aug 31, 2007 | 10:12 PM
accordingly01's Avatar
the way i see it, like putting a lighter fly wheel on the car( not nearly as good though ) you reduce the amount of power that the enging has to use to spin the thing, thus giving you more poneys to play with.
i say to go for it, and atleast you cam say that you have it, and if you modify the engine you wouldnt have to buy it later
Old Sep 1, 2007 | 09:27 AM
BlkCurrantKord's Avatar
Won't make a difference...
Old Sep 1, 2007 | 11:05 PM
marbro's Avatar
The only way it will make a difference is if the adjustable cam gear is lighter then the stock cam gear but even then it wont be amazing gains
triggerman
Mar 6, 2013 08:41 PM
pancho88
Mar 18, 2012 04:14 PM
Sethgreen
Aug 4, 2011 01:58 PM
thunder_x
Aug 18, 2006 02:48 AM
