1997 Front Wheel Bearing
Old Feb 4, 2012 | 06:49 PM
remerbt's Avatar
Default 1997 Front Wheel Bearing
Hey guys,
I need to replace my front right wheel bearing and have a few questions.
I've looked around a bit and I read a couple posts mentioning a bearing/hub assembly that is simply bolt in/out. No pressing of the bearings needed. Is this correct?
Next question is where would you guys recommend I buy the new wheel bearings? Obviously I could find somewhere on my own, but figured this would be a good place to get the best deals and/or possibly help another board member out.
Thanks in advance
Old Feb 5, 2012 | 12:30 AM
Google ericthecarguy wheel bearing. He has good YouTube videos on how to do this.
I am not sure what bearing you want to use. See how expensive the OEM bearing will be. Look for the part number on hondapartsnow.com and search the OEM part number. I have found good deals on OEM parts from Ebay.
Old Feb 5, 2012 | 08:59 AM
You can buy the hub and bearing together as an assembly and install. You'll still need to get the hub assy w/ bearing out of the knuckle, which can be problematic. As PA points out, the Ericthecarguy video will explain the issues.
joenintiesc
Apr 14, 2013 07:29 AM
ryandamartini
Aug 15, 2011 09:18 PM
ScottSoSlick
Mar 18, 2009 03:28 PM
oma93
Feb 6, 2008 12:43 AM
JDMSR20
Dec 20, 2006 01:33 PM
