1997 Honda Accord Reving issue
Old Feb 1, 2013 | 12:48 AM
U&H's Avatar
U&H
Default 1997 Honda Accord Reving issue
Hello,
Just wondering if I could get some help. I have a 1997 accord. 4-cyl. Runs great, but when stopped at stop light/idle it will rev up and down from about 1,000 to 1,500 rpms. Changed out the PCV valve and MAP sensor with no change. Although after changing out the MAP sensor, it has gotten better. Any ideas????
Old Feb 1, 2013 | 06:10 AM
DerekWildstar's Avatar
Hello, and welcome. The mods will probably relocate this thread to the general help forum, where you'll get a quicker response (tends to be checked more frequently than the welcome forum, I've found).
First question: Is your check engine light on?
Old Feb 1, 2013 | 06:29 AM
Check out this thread about setting your base idle.
https://www.hondaaccordforum.com/for...e-speed-38734/
And Derek's right, I'll move it over to Gen.Tech.
Old Feb 1, 2013 | 05:48 PM
U&H's Avatar
U&H
Thank you, and no, the check engine light isnt' on.
Old Feb 1, 2013 | 06:16 PM
Cyclic idle speed can be caused by a number of things, but most frequently the cause is air leak. Check PCV, vacuum line to brake booster, and other vacuum lines for leaks.
Also low coolant level can occasionally cause this problem. Make sure coolant level in reservoir and radiator is good. Check cold condition!
Old Jun 13, 2013 | 07:06 PM
U&H's Avatar
U&H
Default Update on revving issue
Hello,
Just wanted to update....
First of all, thank you for the ideas. Apparently the first problem was air in cooling system. Then cleaned throttle body and such. Then followed the detailed instructions on getting the system reset and voila!! Car runs great now.
smitty.308
May 13, 2013 08:08 PM
ebarrera661
Oct 8, 2010 06:50 AM
ebarrera661
Jan 16, 2010 08:13 PM
Joshporsche
Jun 14, 2006 10:07 PM
Jimmydageek
Feb 23, 2006 03:24 AM
