Accord reving at 3000rpm only
Old Nov 22, 2009 | 12:06 PM
ebarrera661's Avatar
Almost A Senior Member
Default Accord reving at 3000rpm only
Hey guys, I have a 1996 accord dx with a f22b2 in it. I recently swapped the engine due to 2 valves that were bad. Now, with my new engine, it only revs up to 3000rpm and it stats acting as a rev limiter. Also, it won't shift into any gear unless if I let it take it's time. Any help appreciated. Thanks
Old Nov 23, 2009 | 11:22 AM
Exclamation
yeah, but still no luck. I changed the top tranny solenoid and it helped but Still only revs up to 3000rpm and the vroom vroom again and again...I'll post a video of it later guys...Maybe someone can figure out what it is
Old Nov 23, 2009 | 12:04 PM
Default Hello New Member
Welcome to the forum...
Old Nov 23, 2009 | 01:47 PM
Thanks administrator. I'll have the video up in a couple minutes
Old Nov 23, 2009 | 02:30 PM
http://www.youtube.com/watch?v=21-pUU9rB5k Here is the link to show what I am talking about
Old Nov 23, 2009 | 03:15 PM
Your check engine light is on, so find out what code is stored on your ECU. Stop by an autozone and have them read the code then post on here. The code will be P and 4 numbers, i.e. P1234.
The connector for the 96 is behind the ash tray.
Old Nov 23, 2009 | 03:36 PM
the code is for my o2 sensor, it's not working right now, but we did use a used sone from another accord and it went away. Idk, but it's really becoming a big headache
Old Nov 23, 2009 | 03:39 PM
Originally Posted by ebarrera661
the code is for my o2 sensor...
There's 4 different codes for the primary O2 sensor, 4 more for the secondary O2 sensor. Knowing which one might be a good clue for what's going on.
Old Nov 23, 2009 | 04:27 PM
ok guys....I just read my check engine light by shorting it (blue connector and a pin way) and it just keeps flashing 4's here is a video http://www.youtube.com/watch?v=w9VbOAfGRqM Idk how to read that
Old Nov 23, 2009 | 04:47 PM
A code 4 is for the crank position sensor.
It is under the timing belt cover and should have a 4-pin connector sticking out. Unplug sensor and clean it out. You can measure the resistance across pins with the blue and white wire. The resistance should be 1850-2450 ohms.
