Accord reving at 3000rpm only
Old Nov 23, 2009 | 04:50 PM
On my list, code 4 by the flashing CEL method is the crankshaft position sensor.
Either P0335 (low input) or P0336 (range/performance)
Old Nov 23, 2009 | 07:03 PM
ebarrera661's Avatar
Almost A Senior Member
Where exactly is the sensor....Under the belt itself or on top of it ?
Thanks for all the help guys
Old Nov 23, 2009 | 09:43 PM
Its under the belt cover. See this post
https://www.hondaaccordforum.com/for...ad.php?t=29241
Old Nov 24, 2009 | 11:19 AM
ok guys...thanks..i'll check it out ....Does anybody think this could be the reving problem
Old Dec 21, 2009 | 06:16 PM
So after a month of ignoring the car, I finally got around to it. The connector getting cleaned didn't work out, it didn't even help. I need this car running guys so any help is welcomed.
-Thanks
Old Oct 4, 2010 | 05:08 PM
jeremyshane420's Avatar
Im having the same problem. I already replaced the crank sensors still no luck. Anybody have any ideas
Old Oct 5, 2010 | 11:13 AM
  #17
Did you link onto Post #13 from PAHonda and give it a good reading yet?
If not go to it and link up.
Old Oct 5, 2010 | 07:57 PM
  #18
If you swapped in a engine from an earlier model Accord, it will have the CKP sensor in the distributor, not under the timing belt cover. In that case you won't have a CKP sensor to access unless you change engine harness, interior harness, and ECU also.
There might be some way to retrofit a CKP sensor to an earlier model engine.
Old Oct 8, 2010 | 06:50 AM
  #19
no its the original motor
Robert Harp
Jan 8, 2024 06:10 PM
DxGoddy
Jun 22, 2015 01:01 PM
anticrom
Aug 3, 2013 10:21 AM
mcjewel
Mar 10, 2009 01:33 PM
RebelK2
Jan 26, 2007 03:03 AM
