Accord reving at 3000rpm only
So after a month of ignoring the car, I finally got around to it. The connector getting cleaned didn't work out, it didn't even help. I need this car running guys so any help is welcomed.
-Thanks
-Thanks
If you swapped in a engine from an earlier model Accord, it will have the CKP sensor in the distributor, not under the timing belt cover. In that case you won't have a CKP sensor to access unless you change engine harness, interior harness, and ECU also.
There might be some way to retrofit a CKP sensor to an earlier model engine.
