1997 power window relay
Old May 3, 2012 | 09:21 PM
Rcruz's Avatar
I have updated original post with correct year/ Thanks
Redbull, I did all test as on troubleshooting diagram and all checks out. I do have power up to the plug where the switch is on the door. I did check switch and that also checks out.
I'm going to try and go direct to motor and see if i can get it to work. Wondering if drivers motor is out would it effect other 3 remainding windows?
Thanks
Old May 3, 2012 | 09:34 PM
Did you try swapping the two relays?
One motor out would not affect the other windows. I would still test the motors though.
Old May 3, 2012 | 10:16 PM
Rcruz's Avatar
yes I did switch relays and still no change. Just just got done testing power beyond switch to where it plugs into the motor and have power there as well. I'm going to have to say its the motor. I just now need to figure out how to get motor out
Old May 4, 2012 | 07:35 PM
Rcruz's Avatar
I dont know which way to go from here. Put a new motor and new switch still nothing. Like I mentioned earlier I have on the driver fuse kick panel a 10 amp fuse that reads p/w relay. its a fuse not a relay. I get no power with key on or off on either side of the fuse. I did check all relays up front under hood and checks out. what get me is when I disconnect the motor and put a test like at the plug where the motor plugs into. I get power there but still windows dont work. Anymore ideas would be greatly appreciated
Old May 4, 2012 | 07:48 PM
Rcruz's Avatar
Here is a pic of fuse cover on drivers kick panel Note number 5 is a fuse not a relay.
Old May 4, 2012 | 07:54 PM
When you get a chance, put your car info in your signature, so we don't have to go back to the first post to remember your vehicle.
I am also confused. What year is your car?
Old May 4, 2012 | 08:15 PM
  #17
Rcruz's Avatar
1997 accord SE and how do I put car info on signature?
Poorman took care of that for you
Old May 4, 2012 | 08:37 PM
  #18
Yes, that is the fuse. That is the fuse to protect the circuit the power window relay is on. The power window relay is located in the under-hood fuse/relay box, as shown in post #9.
Old May 6, 2012 | 11:18 PM
  #19
Rcruz's Avatar
Finally figured it out. It was a short/loose connection at the drivers harness going into the door. I notice the light would shut off when door is in certain position.
Drove me nuts but glad to have windows working again..
Thanks for all reponses.
Old May 7, 2012 | 06:43 PM
  #20
Good to hear....too many times we never hear back once someone finds the issue.
accordpete
Jan 29, 2014 04:41 PM
jkeely
May 2, 2012 03:48 PM
jfd
Jun 22, 2011 07:36 PM
greg05
Aug 31, 2009 05:32 PM
mmazb3
Nov 26, 2007 03:16 PM
