1998 accord engine code
1998 accord fault codes. I have a 98 V6 4 door accord. Check engine light is on. Code is P1457. Evaporative emission control system leak in canister. I put a hand pump vacuum gauge on the can and no leak. If I clear the code it takes a little while to come back on. Any ideas? Thanks
I posted a pretty detailed bunch of stuff to check for that, if you search for the code number.
Most common is a bad canister vent-shut valve. The EVAP canister is located roughly under the left-rear seat. The CVS valve is on the outboard end of that canister.
But it MIGHT be the EVAP purge valve at the intake manifold, or a half-dozen other things. Check em out before you start throwing parts at it.
Rilex
Aug 14, 2015 12:04 AM
Yessy Consuegra
Jan 18, 2014 08:21 PM
ttommy2tone
Jul 23, 2009 10:07 AM
lkasperiii
Dec 28, 2008 08:40 PM
