1998 accord idles but wont run
Old Jun 2, 2015 | 11:56 PM
wrmartin81's Avatar
They guy at parts store said either injectors or pcm it just doesn't make since that it will run good for a sec then act up then back to running
Old Jun 4, 2015 | 10:28 AM
wrmartin81's Avatar
I took it to Honda and they said its dirty fuel system and said $500 to clean it does this sound right and could someone tell me how to clean the injectors
Old Jun 4, 2015 | 11:19 AM
If they remove injectors and individually clean them w/ special device, that may be reasonable. If they inject fuel injector cleaner in at the fuel rail to clean in place, that's a bit pricey.
Several ways to DIY. You can remove injectors and send them out to a FI cleaning service (check ebay), or rig a DIY injector cleaner (see extensive list of youtube videos on subject).
Did they perform a balance test on injectors to determine that one or more are restricted? If not, this service is a "shot in the dark" and may/may not solve your problem.
Old Jun 4, 2015 | 11:24 AM
wrmartin81's Avatar
I'm not sure he just said fuel tank was very nasty he showed me a sample it was bad and said where it has no fuel filter that the injectors were plugged
Old Jun 4, 2015 | 12:03 PM
There is only an inlet screen below (upstream) the fuel pump in the fuel tank. No fuel filter downstream of fuel pump, as was the case in previous model Accords (90-97).
So the fuel pump was removed to access fuel tank? If not how was a sample obtained? Fuel rail? Tank likely needs to be removed and cleaned. If there is debris in the tank and no cleaning, the same problem may re-occur.
You should know exactly what they plan before paying $500 for a possible fix.
Cleaning may not resolve a FI blockage and new or used injectors may be necessary.
Old Jun 4, 2015 | 12:33 PM
wrmartin81's Avatar
They got the sample at fuel rail and I got the injectors off the screens were full of rust
Old Jun 4, 2015 | 01:12 PM
  #17
Obviously, the fuel pump inlet screen did not catch the particles in the injectors. Tank needs replacing (used or new part) w/ a clean tank. Otherwise you may get to repeat the exercise.
Old Jun 7, 2015 | 11:15 AM
  #18
wrmartin81's Avatar
i cleaned injectors and tank it runs like a brand new car my question would be could i add a inline filter up on the firewall in the peice of rubber hose
Old Jun 7, 2015 | 11:36 AM
  #19
Be sure to get a filter w/ correct inlet/outlet pressure and adequate fllow rate.
I found following which should work.
Fram G6436 Fuel Filter in Line for Honda Accord Prelude | eBay
Old Jun 7, 2015 | 11:50 AM
  #20
wrmartin81's Avatar
Thank you
Luther Stewart
Aug 12, 2020 12:02 PM
blackaccord01
May 16, 2014 09:21 PM
taxman_jones
Apr 9, 2013 12:40 AM
h23frankenstein
Dec 31, 2011 10:15 PM
evansd12006
Oct 9, 2011 09:12 PM
