1998 accord sedan v6 rim change
Old Jul 7, 2010 | 03:37 PM
hondaisme's Avatar
1/2 clearance is with them on the car is that enough?
Old Jul 7, 2010 | 04:59 PM
hondaisme's Avatar
thats on the car,so is the 1/2 " ok?
Old Jul 7, 2010 | 08:56 PM
The 205 60 R16 tire/rim will be almost the same size (0.2 inches taller and same width) as the OEM 205 65 R15 tire/rim.
The 225 60 R16 tire/rim is 3.7 inches taller and .6 inches wider than stock. Your tire may bump into the upper control arm.
If you want to use the 16-inch rims, I would go with the 205 60 R16 tire mounted on the rim.
Old Jul 7, 2010 | 11:08 PM
hondaisme's Avatar
I believe that answers my question, even the strange route I took to ask the right question. I would like to thank all the responses I've received and look forward to chatting with ya'll in the furture. Again , Thankyou
Old Jul 8, 2010 | 09:07 AM
1/2-inch clearance to what again?
Parts of the steering knuckle, ball-joints, steering tie-rod all move around WITH the wheel, so it's normal for them to have pretty small clearance. Even the shock/spring moves with the wheel to some extent.
Clearance to the sheetmetal fender or to the plastic inner-fender liner is a bit different. You have to consider the extreme positions of suspension & steering. The tire width along with the wheel's offset go together in a more complicated way. As the tire tread gets wider, the tolerance in offset gets narrower.
Old Dec 3, 2011 | 12:49 AM
Canuckle04's Avatar
Hi folks,
Quick question, I have 1998 accord v6, 5 bolt. Currently have 17" Acura TL Type S wheels (2003) on the car with 215/50/17. Car is also lowered a few inches.....
I'm looking for some winter tires/rims....so here is my question:
Would the 1997-2001 prelude sh rims fit on my car with 225/50/16? I know the bolt pattern and hub bore etc match up but are these tires ok for the rims?
Thanks everyone.... Your input is appreciated. Please note the rims/tires would only be for a few months of rough winter.
62maxx
Oct 18, 2015 08:20 AM
Rilex
Aug 14, 2015 12:04 AM
Tim
Jul 23, 2012 10:52 AM
62maxx
Nov 21, 2006 12:04 PM
