1998 Honda Accord EX 4CYL - Gauge cluster nightmare.
Old Mar 14, 2011 | 05:49 PM
  #21
Do you have a volt meter?
Old Mar 14, 2011 | 05:50 PM
  #22
techjohnny's Avatar
Sounds like I need one. If it helps solve this problem I'm game.
--tj
Old Mar 14, 2011 | 06:25 PM
  #23
You can unplug that sensor again and see if the original gauge in the car remains at the cold setting.
A digital multimeter cost ~$20 at places like Wal Mart. I got one on sale at sears for $10. You can borrow one from someone as well. They aren't too expensive.
To eliminate the wire as the problem, you need to unplug the wire from both ends. Meaning you will unplug the sensor in the engine bay and unplug the gauge cluster.
You will use the resistance setting (or open/closed circuit) on the multimeter. Touch one lead of the volt meter to the unplugged wire in the engine bay. The other volt meter lead you will touch to a valve cover bolt (ground). You want to see if that circuit is closed or open.
techjohnny
May 17, 2011 08:06 PM
dirtdogg
Aug 31, 2010 12:51 PM
freddieP
Aug 10, 2010 04:11 PM
yiannix
Dec 4, 2008 12:40 PM
marbro
May 20, 2006 10:13 PM
