1999 Accord DX Engine Swap
Old May 3, 2010 | 01:44 PM
cheebster's Avatar
Cool 1999 Accord DX Engine Swap
Hi. I killed my accord engine (Non-Vtech stock in the 1999 DX) and had the engine replaced by some friends at a local garage. The engine they swapped in is a vtech engine. The car runs OK, but it doesn't have the kickdown it used to have.
Was that a bad idea from start ? Is that something that can be fixed in any way ? Some told me i'd need another ECU ? Or maybe just reprogram the existing one ? For what it's worth, i have a Xeltek SuperPro eeprom programmer here.. might be useful ?
Any toughts would be really appreciated. Thanks !!
Old May 3, 2010 | 03:32 PM
deters's Avatar
I would think you have to change the ECU if your going from a non to a Vtec.
Old May 3, 2010 | 05:26 PM
cheebster's Avatar
Ok. Is the ECU different in any way or it's just the programming into the chip that's different ? Thanks.
Old May 4, 2010 | 07:12 AM
You need an ECU that has a circuit that switches the VTEC solenoid. And an input for the VTEC oil-pressure switch. A non-vtec ECU might not even have anything hooked up to those pins?? And it needs the fuel & spark maps for vtec ON as well as vtec OFF operation.
Old May 4, 2010 | 08:15 AM
cheebster's Avatar
Ok. So, what's the steps to follow to find a suitable ECU, do i need to identify the exact engine that has been installed (is there a plate with an exact model # on the engine somewhere, a sticker?) ?
Thanks in advance !!
Old May 4, 2010 | 10:58 AM
cheebster's Avatar
Just found this :
http://cgi.ebay.com/ebaymotors/ws/eB...m=220598814213
Would that be good for me ? I'm reading i need to reprogram the VIN in it in order to use it. What is the tools needed to do this ? Is it possible with a eeprom programmer ?
I've seen the 'immobilizer' unit needs to be reprogrammed ? Any input is really appreciated !!
D-Rod33
Nov 2, 2011 07:38 AM
mfskarphedin
Jun 6, 2010 09:33 PM
jhillblessed
May 10, 2010 11:58 AM
StatzFinest
Feb 10, 2008 11:32 AM
