1999 Accord V6 cam sensor
Old Jan 22, 2015 | 09:10 PM
Wilke308's Avatar
Wow thanks you rock...
Old Jan 22, 2015 | 10:01 PM
You still may want to verify the actual trouble code.
I realize the picture you posted is just a link to a stock picture. My eye sight isn't that good anymore; but, that the picture you linked now looks to be a TDC sensor, which is a completely different sensor than the CKP sensor.
The CKP sensor has a two wire terminal connector; whereas, the TDC sensor has four wire terminal connector.
Old Jan 23, 2015 | 05:29 PM
Wilke308's Avatar
just tested it with scanner P1362
Old Jan 23, 2015 | 06:03 PM
P1362 is TDC1 sensor - no signal.
1. Inspect the connector, connector terminals, and wiring first.
2. If the connector and wiring look okay, unplug the connector, then measure the resistance between the TDC1 sensor's two terminals (No. 1 (Grn wire) and No. 2 (Red wire)).
Resistance should be 1,850 - 2,450 ohms.
3. Check for continuity between body ground and TDC1 sensor's terminals No. 1 (Grn wire) and No. 2 (Red wire), individually. -- There should be no continuity to body ground.
Attached Thumbnails 1999 Accord V6 cam sensor-tdc-sensor-connector.jpg   1999 Accord V6 cam sensor-tdc1-diagnostic.jpg   1999 Accord V6 cam sensor-tdc-sensor-replacement.jpg
Old Jan 23, 2015 | 06:23 PM
Wilke308's Avatar
Thanks, I will keep you posted on what happens this weekend..
Thanks, again
Old Jan 23, 2015 | 06:58 PM
You're welcome. Let us know what you find.
This other link shows the removal of the covers if necessary.
PCV VALVE - Honda-Tech
Old Jan 24, 2015 | 06:29 PM
  #17
Wilke308's Avatar
How do lock the down idle pulley to remove sensor...
Old Jan 24, 2015 | 06:44 PM
  #18
Wilke308's Avatar
How can I send you a Pic.... On what to do next.
Old Jan 24, 2015 | 06:47 PM
  #19
Here are steps #14 and 15, referred to in the TDC sensor replacement instructions.
To attach pictures, just use the Attach Files feature.
Attached Thumbnails 1999 Accord V6 cam sensor-timing-belt-adjuster.jpg   1999 Accord V6 cam sensor-idle-pulley-bolt.jpg
Old Jan 24, 2015 | 07:24 PM
  #20
Wilke308's Avatar
send me a attached file pic of TDC...
Thanks so much for your time..
