1999 honda Accord 4cyl Front Wheel Bearing
Old Feb 12, 2017 | 02:40 PM
Railroader's Avatar
Default 1999 honda Accord 4cyl Front Wheel Bearing
Does one have to completely remove the spindle assembly to replace the front wheel bearing on a 1999 honda Accord LX 4cyl? I saw mention of using a slide hammer to remove the hub, on some models while still on the car. Thanks
Old Feb 13, 2017 | 10:46 AM
A slide hammer can pull the hub out from the bearing, usually destroying the bearing. (but you need to replace the bearing anyway??)
Using a slide hammer on the car means the upper & lower ball joints are subjected to that hammering. I'd be afraid that would lead to balljoint problems down the road.
Old Feb 13, 2017 | 08:26 PM
The Toecutter's Avatar
If it's anything like a 98 Civic, you'll want to pull the spindle off and use a hydraulic press to remove and install the bearings. BTDT and it was a helluva job (did both sides).
JMW
Aug 26, 2013 03:21 PM
joenintiesc
Apr 14, 2013 07:29 AM
3064datazz17
Jun 28, 2012 09:16 PM
Doug Grellner
May 17, 2012 07:20 PM
ScottSoSlick
Mar 18, 2009 03:28 PM
