1999 Honda Accord V6 motor mount replacement
Old Nov 3, 2022 | 08:18 AM
richard9's Avatar
Default 1999 Honda Accord V6 motor mount replacement
I have noticed that there is a small vibration after I drive the car for 20 minutes, and when I am idling at a stop light. The car has approximately 225k miles on it. The motor mounts were replaced about six (6) years ago by local mechanic.
My questions are:
1. How difficult is this task to replace the motor mounts.
2. Are there any instructions available. Other than YT videos.
3. Is it acceptable to use a block of wood on top of a jack to support the oil pan and motor mounts. Therefore, this would hold and secure the engine for motor mount removal.
4. Are the motor mounts on Amazon or Rockauto good enough.
Thanks for any information.
Old Nov 3, 2022 | 11:34 AM
plenum's Avatar
I'm no expert on motor mounts. But if they were replaced 6 years ago. Are you sure it's the motor mounts? If you are sure it's the motor mounts than Rockauto is a good place to start. I scroll past the economy driver. Than I would research the part numbers (on a search engine) to see if you can get a good price on amazon. And look at the reviews. Rock auto has a strict return policy. If you installed the part in the car even if you didn't drive it. And you go to try to return that part and check that box. It says you can't return it and there is no undo. Unless they have changed their policies. This is what I recall.
I just wouldn't think it's the motor mounts with small vibrations.
Old Nov 6, 2022 | 01:28 PM
richard9's Avatar
Thank you very much for sharing this information.
rlalinde1
Jul 26, 2012 11:57 AM
Fixeruper
Sep 28, 2008 08:10 AM
Marc B.
Jun 25, 2008 12:46 PM
drdevo
Jun 23, 2007 06:58 PM
jim97gst
Dec 7, 2006 01:22 PM
