1999 suspension help
Old Dec 14, 2014 | 08:45 PM
McGriff's Avatar
Default 1999 suspension help
I have a 1999 honda accord sedan and am looking to get my suspension checked out (making rough noise when hitting small pot holes at low speed). No matter what, i want it lowered. I do not it slammed but maybe an inch or two lower. Any suggestions? Suspension has to stand up to new england bad roads.
Anyone in the northshore, mass area?
Last edited by McGriff; Dec 14, 2014 at 08:55 PM. Reason: How do i move this to suspension section
Old Dec 15, 2014 | 09:58 PM
I would put the front on jack stands, turn the steering wheel until it locks, then push/pull on the tire. Do this on the vertical (12/6 o'clock) and horizontal (3/9 o'clock) axis of the tire. There should be little movement. If you have movement or noise, try to locate the noise.
IMO, the OEM honda suspension is pretty reliable. I have no opinions on aftermarket suspensions that lower the vehicle. There is a suspension section that will be able to help. It all depends on what you want out of your suspension (smooth ride vs steering).
hondabonda
Apr 21, 2015 11:03 PM
mamtsberg
Mar 17, 2010 09:15 PM
6genex
Jul 1, 2009 08:46 PM
George Knighton
Jan 11, 2006 08:49 PM
sHiNoBi
May 26, 2005 11:42 AM
