2 in one
Old Apr 12, 2007 | 04:04 AM
joninja's Avatar
Default 2 in one
i just have two questions about two diff cars. first off on my 96 accord 119k miles there is alot of shaking, or vibration when in idle i cant even stand driving it. any easy fixes or knowledgeable diagnosis. second question about my 04 accord 33400k miles the maint, reqd, light is flashing for ten seconds after ignition is there a way to clear that myself like on the older models or does the dealer have to do it i dont know what maint needs to be done . the oil change ordered by the dealer isnt due for about 800 miles so any ideas
Old Apr 12, 2007 | 11:41 AM
Default RE: 2 in one
Is your '96 manual or automatic tranny? Auto tranny cars have a vacuum-operated rear engine mount that can fail. It's supposed to get 'soft' during idle in gear.
The reset lamp does that flashing business as an early warning. Whenit'sactually due based onmiles since last reset, the lamp will stay on.
Reset procedure for the 2004 maintenance lamp:
1 - key off.
2 - press & hold the odometer reset button
3 - turn key on while continuing to hold the reset button
- - don't need to start engine, but key has to be in 'run' position
4 - keep holding the button for a while longer
5 - lamp flashes & finally goes out
Old Apr 12, 2007 | 10:26 PM
If your idle is below 700 rpm, your Idle Air Control Valve (IACV) is probably too dirty to work or failed. If low rpm, check IACV solenoid for electrical function and clean if working.
alexkurbiel
May 30, 2013 06:21 PM
toppy42
Nov 14, 2010 03:50 AM
maxst2
Jun 12, 2006 01:54 PM
remington870_20ga
Feb 14, 2006 10:42 PM
nrangerfan
May 20, 2005 01:57 AM
