2000 Accord A/C quit working
Old Jul 27, 2015 | 04:22 PM
SloBurn's Avatar
Default 2000 Accord A/C quit working
My daughter's 2000 Accord A/C quit suddenly. 4 cyl, auto, coupe.
She's away at school so it's hard to work on it-2 hour drive away. Today I went with a can of re-charge, but pressure dial went to the RED when attached. Instructions say "seek professional help" when pressure goes that high....HA! No way....
Because I was in my work clothes, I didn't go any further. So, is there a fuse or relay I should also check? She parks on the street, so no garage to work on it, either. AC worked fine until I gave her the car, any suggestions?? THANKS!!
Old Jul 27, 2015 | 07:47 PM
Start the engine with the a/c turned off and take a look at the compressor. The plate in front of the compressor pulley (compressor clutch) should not spin. Turn on the a/c. Both radiator fans should turn on and the compressor clutch should spin with the pulley. The next step depends on what you find.
Old Jul 27, 2015 | 09:19 PM
Hicksvilleshick's Avatar
x2.
I've learned very recently don't trust the gauges with those cans.
Old Aug 1, 2015 | 11:03 AM
Agree. If compressor is not rotating, then pressure will be equalized in system and high (pressure in psi ~= air temp in degF).
Tony1M
Nov 6, 2023 08:29 PM
BSims66173
Nov 9, 2012 11:52 AM
Driver 1
May 25, 2011 11:33 PM
bglovept
Aug 25, 2010 07:50 PM
jpriest
Feb 1, 2009 11:24 AM
