2000 Accord doesn't start
I left my interior light on so my battery drained and wouldn't start. Jump starting the car worked and I drove it around for 30 mins and the next day, it wouldn't start again. I replaced the battery just now with a new one and now the car doesn't start. The battery is working since the radio turns on and you can hear it try to start when I'm turning the key.
Is this an issue with the starter? I replaced the started about 1-2 years ago.
Thanks.
Thanks.
Here is the terminology I use for starting a car. I turn the key to start the car. The starter spins the engine. When the engine fires up is when I release the key.
So, is the starter spinning the engine normally, or is the engine not firing up?
Your starter is working properly.
The reason for your no start is due to lack of fuel, spark, or compression. You will have to narrow down the problem.
Are the maintenance items up to date like the distributor cap, distributor rotor, and the spark plugs?
A quick check for fuel is to turn the key to the II position, but do not try to start the car. When the check engine light does the bulb check, the fuel pump should turn on for about two seconds. It sounds like a faint buzzing/whirling sound from the back seat, so turn off the radio, blower, etc. and listen carefully.
Do you have a volt meter or a timing light?
So you can hear the fuel pump turn on?
Replacing the spark plugs, distributor cap, and distributor rotor are not very difficult, IMO.
How many miles are on your car? How many miles are on the spark plugs, cap, and rotor?
I will have to listen for the fuel pump and get back to you. I have about 110K miles. I don't remember ever changing the spark plugs, cap and rotor so I have no clue!
The OEM spark plugs should be changed every 90K miles. Get the NGK plugs that are recommended for your car. That information will either be in the owner's manual or on a sticker either under the hood or in the driver's doorjamb. Most auto parts stores will carry them.
nufftalon
Sep 23, 2014 01:21 AM
Clevor
Nov 27, 2013 03:08 PM
misterix
Jul 8, 2009 12:01 PM
