2000 Accord Engine Light
Old Nov 16, 2006 | 03:56 AM
HondaEnthusiast
Default 2000 Accord Engine Light
How do you reset the Engine light? Thanks
Old Nov 16, 2006 | 04:22 AM
Default RE: 2000 Accord Engine Light
First you gotta figure out what year your car is. Then determine whether it's the check=engine lamp or the maintenance-reqd. lamp that you're talking about...
ps... Oops, it's in the title of your post...
Reset check-engine light: There's a fuse box over in the right end of the dash, near the door hinges. Pull fuse #13 in there for a minute.
Reset maint.reqd. lamp: Press & hold the trip-odometer-reset button when the key is turned OFF. Continue holding the reset button for about 20 seconds after turning ON the key. Lamp will flash a few times & turn off.
Old Nov 16, 2006 | 05:52 PM
YeuEmMaiMai's Avatar
did you fix the problem first ?
if not jump pins #8 and #13 and then turn the car on and count the # of short and then count the # of long flashes to get the code
executiveg
Dec 29, 2012 11:38 AM
memphispride85
Dec 10, 2012 12:31 PM
kubafle
Aug 17, 2010 06:51 AM
StatzFinest
Feb 10, 2008 11:32 AM
