2000 Accord engine removal
Old 07-26-2014, 03:46 PM
Mcp609's Avatar
Default 2000 Accord engine removal
I'm trying to remove the engine from a 2000 Accord 5 speed. Everything is loose, but when I start lifting the engine, it wont separate from the tranny. What am I missing?
Thanks
Old 07-26-2014, 04:11 PM
Mcp609's Avatar
By everything is loose, I mean wiring, hoses, exhaust, motor mounts, and 7 bolts between the transmission and engine. All the engines I removed in the past have had automatic transmissions which had flywheel bolts on the engine side. I would rotate engine to remove these bolts, but I don't see those bolts on this flywheel.
Old 07-26-2014, 08:03 PM
LS-300's Avatar
There is a shaft that goes into the back of the engine from the transmission. It is the input shaft for the transmission. It sits in what is called a pilot bushing. You also have the pressure plat that is bolted to the flywheel that you have to clear. But first you need to get the shaft out of the bushing. I generally use a pry bar keeping the engine level with the transmission. If you try to lift too early it makes it more difficult to separate.
Old 07-26-2014, 08:29 PM
Mcp609's Avatar
Thanks for the reply. I removed the 2 bolts on the driver's side drive shaft that goes into the block, is that good enough? Then I pried the transmission from the engine. The flywheel didn't even clear before the crankshaft pulley and the front of engine (accessory drive side) was up against the the engine bay. I'm not sure if the engine can come out without the tranny.
Old 07-27-2014, 09:07 AM
Roader's Avatar
My only experience is with a 6th Gen auto but I don't think the engine will come out by itself w/o the trans. Check out the Online Shop Manuals thread at the sticky Common DIY and Info. Threads.
Old 07-27-2014, 10:30 AM
Mcp609's Avatar
Thanks. Can it still come out the top with the trans?
Old 07-27-2014, 12:12 PM
origami's Avatar
Yes it can:
Old 07-27-2014, 08:38 PM
Mcp609's Avatar
Origami what did you do about the transmission mount?
Old 07-28-2014, 09:36 AM
origami's Avatar
Didn't do this myself, can't help
Old 07-28-2014, 12:59 PM
Mcp609's Avatar
Thanks LS-300, Roader, and Origami. I finally got it out. Not going to be fun putting it back in.
lhawk51
06-27-2012 02:52 PM
humblehyper
12-17-2009 02:59 PM
Gbav1
06-15-2009 09:59 AM
humblehyper
11-05-2008 05:47 PM
zerodoubt
06-22-2006 08:15 PM
Quick Reply: 2000 Accord engine removal
