2000 coupe window regulator
Old Jun 29, 2013 | 08:55 AM
welland99's Avatar
Default 2000 coupe window regulator
Hi all,
I've a problem with the drivers window regulator in my year 2000 . The window was going up and down fine, but when it reached the top, there was a load clicking noise before the auto cut off activated.
For a few weeks, i've been careful to avoid using the window, but today i've had a look inside the door.
The offending part is the pivot for the large gear of the regulator. The pivot is star shaped and it locates in the centre of a coil spring. The teeth of the pivot have worn and become chewed (see photo). It is made of metal (cast alloy?)
Does anybody know where i can get a replacement part? Or, would i need to get a whole new reulator / motor assembly?
Any advice gratefully received.
Old Jun 29, 2013 | 01:12 PM
Regulators are not repairable. A used or replacement part is solution.
Check car-part.com and ebay for used. Some aftermarket regulators are very competitive w/ used parts.
Old Jun 29, 2013 | 03:38 PM
welland99's Avatar
Thanks for the advice. Shame that they are not repairable - most of it is fine - just this one component that is worn out.
Anyone in the UK know a window regulator specialist?
Old Jun 29, 2013 | 04:40 PM
welland99's Avatar
A-haaaa. I've found a supplier of the part i need : Honda Accord 2dr Coupe 96 2002 Left or Right Window Regulator Pin | eBay
Only trouble is, the supplier is in the US, but i am in the UK. Anyone know where i can get one of these in the UK? I have't found a suppplier yet.
Old Jun 29, 2013 | 08:43 PM
You may want to send a message to the seller and find out if they would ship this to the UK.
RaysHondaAccord1994with247.000miles
Mar 15, 2012 01:54 PM
ravenr106
Oct 21, 2011 06:08 AM
ravenr106
Oct 20, 2011 05:32 PM
deserthonda
May 7, 2006 06:17 PM
the_leveler
Nov 26, 2004 10:45 PM
