window motor , regulator or window switch???
Old Oct 19, 2011 | 01:20 PM
ravenr106's Avatar
Default window motor , regulator or window switch???
I have a 1997 honda accord sedan se. My left front window will roll down fine but sometimes it is weak when rolling back up and sometimes it stops all together. How do I diagnose the problem?
Thanks for any help.
Old Oct 19, 2011 | 02:45 PM
Roader's Avatar
Mine did the same thing; probably just dirty/grabby window channels. Take the door panel off. Put the window up. Clean the front and back window channels. An old toothbrush plus some soap and water works well. Try to keep water off the speaker. Rinse & let dry. Then grease the all three inner surfaces of the channels with silicone grease. Home Depot and Lowes sells it in a little plastic container for ~$3. The container has enough grease in it for at least four windows. It's called "silicone faucet grease." Great for lubing suspension bushings too.
Operate the window after you're done but with the door panel still off to make sure the fix took. If not then it should be easier to troubleshoot the problem when you can see what's going on.
Old Oct 20, 2011 | 11:07 PM
Honda_Lady's Avatar
when i had this problem with mine i used silicone spray and that alone cleaned the channel so it moved smoothly up and down, just another tip for you
Old Oct 21, 2011 | 06:08 AM
ravenr106's Avatar
ok thanks. I picked up some silicone faucet grease yesterday. So as soon as I get some extra time Ill try that.
RaysHondaAccord1994with247.000miles
Mar 15, 2012 01:54 PM
ravenr106
Oct 20, 2011 05:32 PM
steveare
Aug 4, 2011 08:21 AM
csr1138
Sep 11, 2010 07:23 AM
wjt
Feb 23, 2007 08:06 PM
