2000 EX door/fender replacement
My car was hit in the door/fender while parked in a parking lot. Repair shops want from $1.5 to $2.5K to repair it. Have any of you had similar damage?
I was thinking about buying a door skin and probably a new fender and installing them myself. Some of the websites show replacing the door skin directly over the damaged skin and using some sort of glue to weld the two pieces together. On the front fender, I wonder how difficult it is to remove/replace. I've also found complete door assemblies for $350.00. I wonder if that would be the easiest.
New fenders are relatively easy to install, ASSUMING no underlying damage.
The thing is, if the pillar between the fender and the door is in anyway out of alignment, you're going to need to have that taken care of before a new fender and door will fit.
jza240sx
Apr 30, 2013 04:14 PM
BrooklynAccord
Feb 25, 2008 11:48 AM
PJ_STYLES_95AccordEx
Oct 24, 2007 09:58 PM
