2000 Honda Accord Alarm Light on driver door.
Old Sep 15, 2015 | 11:16 PM
Tran Huy's Avatar
Exclamation 2000 Honda Accord Alarm Light on driver door.
Hi everyone,
Today, I tried to clear my Check Eng. Light, so I pulled the number 13 7.5A Clock back up and I tried to pulled out number 10 11 12 14 too...
So now, the Alarm light at driver door is turned off and the alarm does not turn on when I tried to pull the door's lock inside. But I can turn the alarm on by my Remote, but after lock the doors by Remote, no sound + light in rear.
Please help me to turn on the Alarm light again. Thank you so much.
:cry::cry::cry::cry::cry:
Old Sep 16, 2015 | 07:46 AM
Just to confirm, which it sounds like, this an EX trim level with the factory alarm?
Is there anything else electrical, other than the security system not working? If there is something else electrical not working, then this may indicate a possible fuse issue.
Otherwise, for the system to arm, the ignition switch must be off, the key must be removed, and the security control unit must receive signals that the doors, hood, and trunk lid are closed and locked. If one of the switches is misadjusted or there is a short in the system, the system will not arm. As long as the control unit continues to receive a ground signal, it senses that the vehicle is not closed and locked, and the system will not arm.
Old Sep 16, 2015 | 07:48 AM
Also, re-check that passenger side Fuse No. 13 is firmly in.
Rob2000AccordLX
May 9, 2014 06:23 PM
Arseman03
May 26, 2013 07:38 AM
jza240sx
Apr 30, 2013 04:14 PM
losrico
Oct 18, 2012 05:26 PM
