2000 V6: Engine Mount Replacement Order?
Old Oct 29, 2013 | 03:41 PM
Florida_Frank's Avatar
Default 2000 V6: Engine Mount Replacement Order?
I need to replace both the front and right-side engine mounts, but NOT the rear mount. I will use a scissor jack and block of wood under the engine to support its weight.
Is it safe to replace both mounts at once? If not, what order should I do them in? Maybe replace the front mount first, but leave its bolts loose while I do the right-side mount?
Old Oct 29, 2013 | 03:48 PM
I have never heard of an order of installation, but you should make sure that no binding occurs when bolts are installed. Easy to crossthread a misaligned bolt leading to bad consequences.
I think your suggestion of front first and side 2nd makes sense. Both may require some engine support for alignment of new mount.
Old Oct 29, 2013 | 09:26 PM
Thanks for the quick response!
Old Oct 30, 2013 | 02:08 PM
This isn't for the V6, but there WAS a sequence for the 98-99 4-cyl mounts. It was in the text of the Helm shop manual procedure for R&R of the engine. All mounts were installed, loosely. Then some tightened, shake the engine, tighten others, etc. Something like that.
Florida_Frank
Oct 25, 2013 04:47 PM
gxl1927
Sep 12, 2009 09:46 AM
baer77
Feb 27, 2009 03:47 PM
gilwood
Sep 18, 2007 09:19 AM
Kyle
Mar 17, 2007 01:56 AM
