2001 Acccord Alarm Factory Alarm
Old Apr 30, 2008 | 01:01 PM
prkarpi
Default 2001 Acccord Alarm Factory Alarm
Hi,
I have a little problem with the factory alarm in my 2001 Accord Coupe 6 cylinder EX. My alarm won't trigger, even though doors, trunk and "panic" buttons work well. I can open and close doors with transmitter, but the horn won't sound and lights won't flash when triggering with transmitter. Further, the "security button" on the driver's door won't flash.
Can someone recommend a solution? Or perhaps tells me where the alram module is located.
Thank you.
PR
Old Apr 7, 2009 | 02:53 PM
JRcommuter
Default Same Problem
Hi,
I am having the exact same problem, doors lock and unlock with FOB but no horn or lights, and the security light on the door near the lock is not coming on.
Did you figure your problem out? Were there any replies?
Thanks in advance!
-Dave
Old Apr 7, 2009 | 03:38 PM
hondadude's Avatar
check the hood latch switch....system does not arm if it thinks the hood is up
Old May 30, 2009 | 02:58 AM
sharky06
bump for the same problem for my wifes 04 accord. I did a search and the common diagnosis is fuse and actuator. Can someone confirm...thanks.
Boricua54
Jun 15, 2023 10:11 PM
Chicago
Jul 29, 2013 08:06 PM
Illadelfian
Oct 1, 2007 12:30 AM
dboy
May 8, 2007 08:45 PM
1a9c9c9ord
Oct 25, 2006 01:21 AM
