2004 Accord - Door lock acting funny
Old Apr 9, 2009 | 12:38 PM
RTM1216
Question 2004 Accord - Door lock acting funny
Hi all,hopefully someone has run across the issue I'm having with my 2004 Accord's driver's side door lock.
When I lock the door with either the FOB or the interior switch it works great. But when I use either method to un-lock the door the lock pops up then when I go to pull the handle to open the door the lock goes down about halfway not allowing me to open the door. If I'm inside the car I have to manually pull the lock up to get out. If I'm outside I need to manually unlock the door with the key in order to open it.
This is only occuring on the front driver's door. Any advice on what could be causing this is greatly appreciated.
Old May 30, 2009 | 03:20 AM
sharky06
bump for this issue to be resolved. Running into the same situation and hoping that its the fuse which would be around 3 bucks.
Doublel
Mar 11, 2013 07:57 AM
acewinston
Apr 2, 2011 04:02 PM
greg9442
Sep 3, 2009 03:31 PM
nubuck83
Sep 3, 2009 09:46 AM
Andyf
Oct 28, 2007 05:04 PM
