2001 Accord EX 2.3 Crank/No Start
Old Jun 28, 2021 | 10:00 PM
klannan11's Avatar
Default 2001 Accord EX 2.3 Crank/No Start
Good evening,
I’ve been beating my head on my sons car trying to figure it out. At times the car will crank and not start. During this time the green key light is not illuminated on the dash. At times I can tap under the steering wheel bottom panel and the green key light will come on allowing the vehicle to be started.
He just purchased it from an individual so I don’t have a lot of history on it. I’ve heard possibilities of the immobilizer, main relay, fuel pump relay. Any ideas out there or some best practices to figure this one out?
thank you,
Kyle
Old Jun 28, 2021 | 11:25 PM
The green key symbol would point towards the sensor in the steering wheel for the immobilizer. Maybe a loose/corroded connection?
Try using a spare key if available, to see if the issue is with the transponder that sends the signal from your key.
Old Jun 28, 2021 | 11:28 PM
klannan11's Avatar
I only have the one key for the vehicle/no remote if it matters.
Old Jul 5, 2021 | 05:33 AM
klannan11's Avatar
Replaced the main relay that is under the dash and have had no starting issues with the vehicle since. I hope this helps someone out there.
GHIBBS
May 15, 2022 04:22 PM
Tkwagon
Mar 8, 2021 05:49 PM
MikeStarkk
Jun 26, 2018 11:16 AM
Tyltong123
Oct 30, 2008 07:30 PM
jastunna1987
Sep 1, 2007 07:20 AM
