2001 Honda Accord LX A/C trigger when change air flow to "DEFROST" position.
Old Jul 15, 2009 | 06:43 PM
moshlub
Default 2001 Honda Accord LX A/C trigger when change air flow to "DEFROST" position.
I have a 2001 Honda Accord LX, when I turn on the heat and set the air flow to defrost or defrost/feet position it trigger the A/C to turn on too and sometimes my LCD clock just keep flickering and then the clock were off. I removed the radio and check the wires everything appear to be good conditions, does anyone have any clue what's going on? I appreciate any helps
Thanks
Moshlub
Old Jul 16, 2009 | 06:35 AM
Welcome!
The AC is supposed to come on when you select defrost, to dehumidify the air. You CAN switch it off, unlike the 2003+ cars where you're unable to switch it off.
The LCD clock is probably a separate issue. Is it the illumination that flickers, or the digits themselves?
Old Jul 17, 2009 | 05:29 PM
moshlub
Is that right? wow, I didn't know that was normal, I though something's wrong with it, this is the first Honda I ever owned. . .
As for the clock, I don't really know how to explain it, sometimes it just start flickering on/off and all the clock elements lit up and went off, etc, if I punch the dash near the clock sometimes it stop for a few minutes.
dylan1986
May 29, 2015 08:45 PM
godey
Jun 25, 2014 03:54 PM
jfidelh
Sep 13, 2011 11:20 PM
Wingdreamer
Apr 25, 2011 12:16 PM
AccordAnimal
Aug 11, 2010 08:04 AM
