2001 Honda Accord LX rear passenger door lock
Old Sep 7, 2012 | 11:49 AM
amituofo's Avatar
Default 2001 Honda Accord LX rear passenger door lock
Hello expert,
My 2001 Honda Accord LX rear passenger door lock does not work when using remote, or from any door switch. The only way to lock/unlock is to pull or push it directly.
I searched online indicating that it may be the actuator problem. Can you confirm?
Thanks
Amituofo...
Old Sep 7, 2012 | 11:56 AM
See this link on testing the actuator with 12 volt battery power and replacement if necessary.
https://www.hondaaccordforum.com/for...acement-48225/
Old Sep 8, 2012 | 10:43 AM
amituofo's Avatar
Hello redbull-1,
I tested with the 9v battery. The actually made a low clicking sound, but it didn't actuate the lock. I take it it's broken, right?
Thanks.
Amituofo
Old Sep 8, 2012 | 12:00 PM
If you applied power directly to the actuator and it didn't lock/unlock then yes it is bad or the linkage is "binding" in such a way that it won't move.
Old Sep 8, 2012 | 05:22 PM
To be sure, try to use 12 volts instead of 9 volts. I tried 9 volts on an actuator before and didn't get movement; but, 12 volts did.
amituofo
Jun 15, 2013 08:32 AM
Doublel
Mar 11, 2013 07:57 AM
Motman Idaho
Mar 22, 2012 10:20 PM
djrockewfewtimez986
Jul 6, 2010 05:34 PM
accord1998
Apr 3, 2008 04:47 PM
