2001 V6 Accord IAC valve location
Old Sep 7, 2011 | 04:24 PM
Girlsplay basketball's Avatar
Default 2001 V6 Accord IAC valve location
Need help locating IAC valve in 01 V6 accord. Idle goes from 1000-1200, check engine light and TCS light all acted up at once. Please help. Picture of valve and location would be great. Thanks!
Old Sep 8, 2011 | 10:20 AM
onmyownaccord's Avatar
Girlsplay basketball,
The Idle Air Control valve on your '01 V-6 is located underneath your throttle body. Honda calls this part the "rotary air control valve set" instead of the AIC valve, but it is one in the same.
The rotary air control valve is depicted as ref #2 in this '01 Accord V6 throttle body diagram.
Let me know if you need additional help
Old Sep 8, 2011 | 11:50 AM
If you haven't extracted DTC's (codes) take to Autozone or others to get the ECU code (Pnnnn). Post codes for help.
Old Sep 8, 2011 | 08:09 PM
Default Found valve! Thanks!
I found the valve and looks like a fairly easy job to do. Thanks for your help. Also the idle has went back to normal. Can I take it off and just clean it rather that replace with a new $150 part? I will have code checked this weekend.
Old Sep 8, 2011 | 08:24 PM
Cleaning it often works, so try that.
I'm gonna move this to General Tech where it belongs.
Silver98V6
Apr 20, 2011 10:21 PM
Brian R
Jul 30, 2010 01:41 AM
jamrock
May 20, 2010 06:45 AM
markrb
May 1, 2008 12:34 AM
