2002 4cyl automatic tranny problems
Old Jan 5, 2009 | 12:01 PM
jtech
Default 2002 4cyl automatic tranny problems
160,000 miles, 10,000 miles ago changed tranny fluid back to back with the dealership fluid. If i am driving, stop at a red light briefly (catching an already red one) when greenaccelerate the car goes to shift out of first into second and seems to slam into what i think is third. The problem had got progressively worse. Now if I am at a complete stop for say 3 or so minutes and accelerate it shifts fine. Its only on a sorta stop and go. Help would be appreciated.
Old Jan 7, 2009 | 12:05 PM
jtech
Default RE: 2002 4cyl automatic tranny problems
bump
Old Jan 8, 2009 | 10:52 AM
jtech
No One can help?
Old Jan 8, 2009 | 11:17 AM
finch13's Avatar
It is a known issue for the 6th gen (1998-2002) and some 2003 auto trannies to just randomly die at any mileage because of a design flaw
Honda was sued in a class action lawsuit and the warranty extended to 7 years from delivery date/109,000 miles on the transmission. It sounds like yours may be beginning the ends of its life. Some people reported that Lucas Transmission Fix/Oil will extend its life a little bit.
Old Jan 8, 2009 | 02:39 PM
jtech
So its probably not easily fixable, it would need a complete rebuild? Is buying a reman an option? Or will i have the same prob?
Old Jan 8, 2009 | 03:02 PM
finch13's Avatar
You rebuild/buy a new one for that same price as a manual tranny swap. Either way, the transmission isnt fixable and you will run into the same problem again down the road.
Old Jan 8, 2009 | 03:16 PM
Another one bites the dust.
This is a fairly common problem as finch said. I have heard horror stories of people replacing the transmission 3 or 4 times. If you were to get a new one they generally come with a 3 year 30,000 mile warranty or something close to that, but after that there is nothing to say it would not happen again.
Old Jan 8, 2009 | 03:29 PM
falkore24's Avatar
IMO, sell it and get something smaller that has an engine prepped for forced induction, then put a little turbo on it ......
Old Jan 9, 2009 | 11:08 AM
jtech
I really appreciate the help i wish i could add to this site, my knowledge is on sportbikes, machining and engineering. Its the wifes car, does any one have a list of what i need to do the manual tranny swap. Odviosly the manual tranny, but computer, torque converter, diff tranny lines, shifter assembly etc.
Old Jan 9, 2009 | 11:18 AM
Someone around here has a real list, but until then....
You need hardware in the console, like brackets & stuff to hold the shift lever itself. Its a cable shifter, so theres 2 cables going to the manual tranny.
Clutch & brake pedal assembly to replace your brake pedal asy.
Clutch hydraulic system (MC & slave & tubing between). Clutch MC doesnt always have the fluid reservoir included because its not directly mounted (its on a hose).
Your radiator has a tranny cooler built in. Leave it there; manual tranny has no need for that cooler.
Flywheel from a manual-tranny engine. ALSO THE BOLTS - they are longer for a MT flywheel.
Clutch assembly = clutch disk, pressure plate, pilot bearing, throw-out bearing.
Instrument cluster without the PRND32 lamps?
Yourcomputeris a PCM - combined engine & trannycontrol module. I dont know if you can simply disable the portion that controls the tranny. So maybe you need a new PCM.
