2002 accord 2.3 auto
Old Aug 13, 2012 | 06:32 PM
comuter's Avatar
Default 2002 accord 2.3 auto
hello i am a new member. changing my timing belt i may have damaged my rear balance shaft. do they just slide out the side? what do they balance? there is a vibration at low rpm.
Old Aug 13, 2012 | 08:53 PM
ahh...going to need a bit more info.
Old Aug 14, 2012 | 07:19 AM
How is it damaged? IIRC, the rear balance shaft is driven through a geared sprocket, so maybe only that sprocket is damaged???
Part #1 in this drawing.
Old Aug 14, 2012 | 05:48 PM
comuter's Avatar
hello mr blake, thank you for the reply. the timing belt was on correctly. the balance shaft belt was timed 180 degrees off. i thought i damaged the rear shaft when i attempted to rotate the crank with the temporary alignment bolt in the rear balance shaft. after correctly installing the balance belt with the engine at tdc it eliminated the vibration. thanks for the help. thats what i get for going to the university of utube.
Old Aug 15, 2012 | 07:22 AM
HAHA, glad it worked out OK. THANK YOU for coming back to post the end of the story. It's too many times we never find out how things worked out.
NeyVtec
Apr 11, 2015 12:57 AM
Chuck Shin
Nov 16, 2014 11:41 AM
JEB0007
May 15, 2011 07:31 AM
JEB0007
May 4, 2011 05:57 AM
Raiden1338
Mar 9, 2010 04:12 PM
