2002 Accord Bad isle/won’t start
Old Jul 27, 2020 | 02:48 AM
CG6Dude's Avatar
Default 2002 Accord Bad isle/won’t start
Hi Everyone,
I was driving up to my gas station and revved my Manual 2002 Honda Accord 2.3L to 4K rpm and there was a sudden pull as if VTEC engaged, so I let go of the throttle and the engine died on me. Engine hasn’t been able to start properly since. It cranks and turns over, even idles weakly at like 300 rpm for about 10 seconds, then it dies. I have attached link of my YouTube video showing the bad idling and eventual stalling. What could the issue be?
No CEL. No Codes.
Old Jul 27, 2020 | 07:14 PM
Your check engine light is on, so I'd start with scanning with an obd2 code reader.
For an engine to run you need air, fuel, spark + timing, and compression. The code may help direct you where to start diagnosing. Have you had any recent work done on the car or any issues before this current problem?
Old Jul 28, 2020 | 04:26 PM
CG6Dude's Avatar
i just checked with a OBD2. No codes came up... I removed the spark plugs to see and they were filled with soot. The engine spits out lots of black smoke when I’m cranking it. It feels like it wants to start
Old Jul 28, 2020 | 10:25 PM
nomad2020's Avatar
black smoke is an indication that engine air/fuel mixture is way too rich
few things could cause that ,, from a simple dirty air filter to a bad o2 sensor, map sensor ect ( engine coolant temperature ) sensor , if faulty, they could send a faulty signal to ECU to richen fuel mixture
don't start replacing parts till you properly diagnose the cause
Old Jul 29, 2020 | 01:42 PM
Blown FPR is another possibility to check for. There should not be any fuel in the vacuum line from FPR to manifold.
Old Jul 29, 2020 | 07:35 PM
CG6Dude's Avatar
Got it fixed. Checked timing and the timing belt jumped
Old Jul 30, 2020 | 10:39 AM
nomad2020's Avatar
now you need to find out why belt jumped ,that's got to be a reason for it ,,,,,, is timing belt worn? missing tooth? was really loose ? time to replace it ??
Luther Stewart
Aug 12, 2020 12:02 PM
longdistance
Nov 11, 2009 09:37 AM
ScottSoSlick
Apr 29, 2009 07:02 PM
penultimeta
Oct 28, 2008 09:11 AM
KDXPHIL
Jul 18, 2006 01:08 AM
