2002 Accord LX 4 cylinder - Loud grinding in front end
Old Dec 26, 2024 | 03:14 PM
KED1112's Avatar
Default 2002 Accord LX 4 cylinder - Loud grinding in front end
I have a loud grinding that increases when I accelerate and stops when brakes are applied. No reduction in grinding when I turn the car R or L. If this is not a wheel bearing, is this more likely the CV axle failing where it goes into the differential or an input shaft bearing issue? The grinding is loud and is definitely not a knock or growl sound.
Old Dec 27, 2024 | 07:55 AM
kris_loehr's Avatar
Look at front brake pads. Their is a tab that hits the rotor to tell you the pads are worn out.
streetroc85350
Jan 22, 2013 09:49 PM
bigjammer
Aug 1, 2012 09:36 AM
Famous0ne
Feb 14, 2012 11:58 AM
FrankvH
Aug 22, 2010 05:24 PM
amyandrew2
Apr 15, 2006 03:40 PM
