2002 Accord LX 4 cylinder - Loud grinding in front end
I have a loud grinding that increases when I accelerate and stops when brakes are applied. No reduction in grinding when I turn the car R or L. If this is not a wheel bearing, is this more likely the CV axle failing where it goes into the differential or an input shaft bearing issue? The grinding is loud and is definitely not a knock or growl sound.
streetroc85350
Jan 22, 2013 09:49 PM
