2002 Honda Accord EX V6 transmission slip between 1 and 2
Old Aug 10, 2020 | 04:30 PM
brroja49's Avatar
Default 2002 Honda Accord EX V6 transmission slip between 1 and 2
Any suggestion/help would be greatly appreciated...
My 2002 Honda Accord EX V6 transmission is slipping/jerking between 1st and 2nd gears only, otherwise is seems smooth. I realize there are tranny issues with this model, but I am hoping to catch it early and save or prolong it's life. I plan to drain and refill fluid using genuine ATF DW-1. Anything else I could, should or shouldn't do? THANK YOU!
Engine
Type: Aluminum Alloy: V-6
Displacement (liters): 3.0
Horsepower @ rpm (SAE net): 200 @ 5500
Torque (lb.-ft. @ rpm): 195 @ 4700
Compression Ratio: 9.4: 1
Valve Train: SOHC: 24-ValveVTEC
Fuel System: Multi-Point Fuel Injection
Ignition System: Electronic w/Immobilizer
Drivetrain
Type: Front-Wheel Drive
Automatic Transmission: 4-Speed (available): STD
Final Drive Ratio (MT/AT): NA/4.20
Old Aug 10, 2020 | 07:54 PM
nomad2020's Avatar
you can try the Lucas luc10009 transmssion fix, cost around 10-12 dollars , it might help and buy you some time before tranny eventually has to be repaired ,,
depends on how many ozs you add you might have to drain some tranny fluid ,, it think bottle comes in 24 oz ,,
if you decide to try it,, hope that it helps,,,
Old Aug 10, 2020 | 09:43 PM
The friction material on the clutches may be worn enough that the fluid may not fix the issue, but changing the fluid is worth a shot.
If you stop by a parts store, have them scan for codes just to be sure that this isn't a faulty electrical component on the transmission.
You may want to clean any debris blocking the shift solenoids and filter gasket screens.
You may want to look into pricing for a rebuilt transmission to get an idea of the future cost to replace if the trans stops working in the near future.
Old Aug 12, 2020 | 10:03 PM
brroja49's Avatar
Thanks. I have heard cleaning the solenoid screens can do wonders.
Old Aug 13, 2020 | 07:14 AM
shipo's Avatar
Do NOT use Lucas anything; drain the ATF from the transmission, refill it, drive a few miles, and then repeat two more times.
Old Aug 25, 2020 | 02:50 PM
13jeeps's Avatar
This is the only thing recommended on Honda transmissions
Old Aug 25, 2020 | 03:15 PM
shipo's Avatar
What are you trying to say, that you think a Lucas product is recommended for Honda transmissions? If so, please provide references Honda publications which support that. As for as I know, literally ALL aftermarket treatments are expressly forbidden for use in any and all Honda transmissions.
Old Aug 26, 2020 | 01:42 PM
13jeeps's Avatar
lol...wow... no silly. drain and refill
Old Aug 26, 2020 | 01:48 PM
shipo's Avatar
LOL, cool, we're on the same page then.
Honda info
Apr 29, 2020 02:01 PM
JacobDibble
Mar 12, 2020 08:18 AM
DrewJay
Mar 7, 2012 08:14 PM
Immortal78
Jun 24, 2011 06:46 AM
ScottSoSlick
Apr 29, 2009 07:02 PM
