2002 Honda Accord limp mode??
Old Nov 3, 2010 | 07:58 PM
Well that gen is known for having trans issues but I have to ask again...in neutral it has the same issue. So you have no codes, correct, and in neutral you have the same issue as when in drive.
The wife's '07 Pilot has a rev limit on it of some sorts. In park or neutral it will not let you rev the engine past?????something, can't remember-it cuts out. In drive (auto) you can stand on it an it will go to red line, or close to it, without any issues.
And no I don't try to race or go more the then the usual 5 mph over the speed limit...just every now and then I like to get to the speed limit as quick as I can. Of course that is only when she lets me drive it.
Old Nov 4, 2010 | 08:30 AM
imsohungover's Avatar
Yes same issue in drive. That's the part that is confusing me. I would understand if car was in neutral and I can hit redline but it revs only to 5k. Then in drive it's goes up to about 3k and then shifts gear but not smoothe. I'm ready to take it toa mechanic soon if I can't find a solution soon
Old Nov 5, 2010 | 11:45 AM
can someone please help before i have to take the car in to the shop?
Old Nov 8, 2010 | 09:34 PM
anyone?
Old Nov 9, 2010 | 10:23 AM
Funny that it's getting no more error codes. It's almost like the ECU isn't getting a signal from the VSS; it might do that if it thinks the car isn't moving. But if that's it, it should throw a code for the VSS.
Old Nov 10, 2010 | 08:12 AM
So what does that mean? Ecu problem?
Old Nov 10, 2010 | 06:41 PM
  #17
I usually try to rule out everything else first because blown ECUs are kinda unusual. I thought it was a smart@$$ way of asking you whether there were any other error codes that you didn't tell us about because you thought they were unrelated.
Old Nov 11, 2010 | 08:18 AM
  #18
Yea I honestly think I got a bad transmission problem now
Old Apr 8, 2017 | 08:18 PM
  #19
Steve Roberts's Avatar
I have a 02 accord 4cyl Auto ex that's doing the same thing... Im in the process of trying to figure it out now. Limp mode is what's mine in too
Old Mar 29, 2025 | 02:27 PM
  #20
Ihatemyhonda's Avatar
Originally Posted by imsohungover
can someone please help?!!?
My 04 was doing the same thing and come to find out it was the vvm sensor I believe is what it's called it is located right above the oil filter for the variable valve timing system.
hondavtec94
Feb 27, 2014 12:54 PM
argarcia86
Apr 5, 2012 10:42 PM
sitedude
Oct 22, 2011 02:07 PM
thumper44
Sep 22, 2010 05:02 PM
ronjr8102
Aug 31, 2010 07:05 PM
