stuck in limp mode 94 honda accord lx vtec
Old Feb 27, 2014 | 09:23 AM
hondavtec94's Avatar
Default stuck in limp mode 94 honda accord lx vtec
i have a 94 honda accord lx vtec 2.2 5 speed manual and the map sensor went bad on the car so i replaced it and my car is still stuck in limp mode and that was the only code that was thrown at me.
i tried disconnect battery but i havent tried removing the #13 fuse but was wondering if there is any ideas i should try first
help please and thank you!
Old Feb 27, 2014 | 11:08 AM
Fuse won't do any more than disconnecting the battery. Anyway, the "#13 fuse" is for 98-02 and your 94 probably has a different fuse to pull. The only reason to pull a fuse on 98-02 is so you don't clear the memory of your radio which it's already too late.
Old Feb 27, 2014 | 12:54 PM
You can test the wiring for the MAP sensor and the MAP sensor to see if they are okay. This video is for a 98 Civic; so, the wiring colors are a little different than your 94 Accord; but, the test is essentially the same. I've also attach an image of the MAP sensor wiring for your car.
Attached Thumbnails stuck in limp mode 94 honda accord lx vtec-map-sensor.jpg
imsohungover
Mar 29, 2025 02:27 PM
EK99HATCHBACK
Mar 5, 2015 10:46 AM
truballer328
Mar 18, 2014 03:42 PM
Abhishek719
Nov 27, 2011 11:08 PM
