eng rpm
Old Feb 27, 2014 | 06:31 AM
gt massive2000's Avatar
Default eng rpm
I just bought a 97 accord the tranny when I was stuck in some snow and the reverse clutch broke. I got a tranny from jdm after installing and went on test drive I notice the rpm staying at around 3000 doing 60 mph is this normal when in in d4 and going 60 if I drop to d3 the rpm goes up so I am thinkthink the overdrive is working any idea
Old Feb 27, 2014 | 08:29 AM
shipo's Avatar
Four cylinder motor or V6? I'm assuming an automatic transmission here.
Old Feb 27, 2014 | 11:03 AM
Maybe the JDM transmission has lower gearing?
Old Feb 27, 2014 | 02:59 PM
Roader's Avatar
Look for the trans code stamped on the case. This page will tell you what the gear ratios are:
cb7tuner(dot)com/vbb/showthread(dot)php?t=37839
There are lots of trans ratio/speed calculators out there. Put the ratios and tire size in and see what the RPM is supposed to be @ 60mph.
Torque converter lockup works in both D3 and D4. This page explains how it should work:
Honda Electronic Transmission Troubleshooting
gt massive2000
Feb 27, 2014 11:54 AM
CRVtoAccord
Jul 3, 2007 01:09 PM
62maxx
Oct 26, 2006 01:04 PM
Parkavenue
Sep 18, 2006 06:59 PM
accordn2me
Dec 6, 2005 01:30 PM
