2002 Honda Accord - Power outlet (cigarette lighter) not working.
Old Jan 20, 2008 | 02:15 PM
odabiri
Default 2002 Honda Accord - Power outlet (cigarette lighter) not working.
Hi Everyone,
My power outlet (right up under my radio) won't work. I've checked all fuses and they are all good. When I checked the fuse map, there wasn't a specific fuse for the power outlet or cigarette lighter, however, I checked all and I said they were fine.
I would like to use my power outlet, but I can't get it to work ...
Can anyone help me with this?
Thanks
Old Jan 20, 2008 | 06:19 PM
Chiovnidca's Avatar
Default RE: 2002 Honda Accord - Power outlet (cigarette lighter) not working.
Recheck fuse 9 in the passenger under dash fuse box.
Old Jan 20, 2008 | 10:24 PM
nafango2's Avatar
make sure you check all the fuses in the engine compartment AND in the fuse box thats in the inside by the pedals.
if your still getting no power it may be the specific thing your plugging into the outlet, test it with a voltimeter.
Old Oct 27, 2011 | 01:35 AM
Netter's Avatar
Stupid question, but how do I know if the fuse is bad using a visual inspection? I don't have a volt meter.
Old Oct 27, 2011 | 09:06 AM
bigpat's Avatar
Almost A Senior Member
To check a fuse, remove it from the panel. Hold the fuse up to the light and look closely at the sides of the plastic fusehead. If it is blown, the center metal element in the plastic will be broken/burnt/discolored. If not, then the fuse is likely still good.
Try using the stock cigarette lighter to check for heat/power to the socket.
cukaracha
Jul 16, 2014 05:00 PM
skyview222
Aug 6, 2011 01:38 PM
Fabb Capo
Jul 8, 2011 07:37 PM
vikasg14
May 27, 2010 10:29 AM
coolgmslife
Jul 5, 2007 10:36 PM
