2003 Accord
Old Oct 14, 2014 | 12:20 PM
hp2003accord's Avatar
Exclamation 2003 Accord Transmission question
I have 115K miles on this car. The other day it shut off and when I restarted it, the transmission would shift but not engage. After about an hr it started and shifted fine. A mechanic said these cars are known to have a screen that dislodges in the transmission causing the fluid to stop flowing. Is this true?
If not, what else could it be?
Old Oct 14, 2014 | 02:30 PM
Low fluid level. Drain/replace ATF w/ Honda DW1.
Is Check Engine Light on or D4 light flashing? If yes, get the codes from AZ or ORiellys. Post them here for help.
Old Oct 15, 2014 | 07:54 AM
Low fluid level makes a lot more sense than what the crook mechanic was saying.
Also, no lights came on.
How could the fluid level decrease without any leaks though?
Old Oct 15, 2014 | 09:06 AM
How do you know there are no leaks?
Check fluid level. Fluid can leak from AT into cooling system and vice-versa if AT cooling loop is compromised. This would not result in ATF on the ground and can quickly damage AT.
nightowlll2010
Jun 1, 2013 12:55 PM
hoonhooon
Jan 7, 2008 06:47 PM
Jeff247
Mar 28, 2007 04:22 PM
gdr_11
Apr 7, 2005 08:58 PM
