2003 Accord - ABS Light
Old Jul 22, 2013 | 03:45 PM
Dr. Drivability's Avatar
ABS only works going forward.
Old Jul 22, 2013 | 08:29 PM
catkins66's Avatar
I pulled things back apart this evening. I found some bits of plastic debris from drilling. I cleaned it out as best as possible and put the sensor back in. The light remained on, even after I pulled the battery for a few minutes. so I took it back to read the error codes and had two errors pop up.
13-1 front left wheel speed sensor short or open, and 22-1 left front pulsar malfunction.
I don't know if the 13-1 indicates the new sensor is now damaged too, or if that is now driven by something else. the pulsar malfunction sounds like the magnetic ring mentioned earlier.
I'm wondering if these codes are from the initial ride I took the car on. I'm thinking of trying to clear the codes and than see what it does. Do you know how to clear the codes, or does that have to be done with a code reader?
thanks!
Old Jul 22, 2013 | 08:46 PM
Magnetic debris can also cause the encoder malfunction.
Old Jul 22, 2013 | 08:49 PM
catkins66's Avatar
any ideas on how to get it out thought the sensor hole? I used vaccum, air compressor.... brake cleaner? I'll give that a shot, but I assume you have to reset the codes afterwards, or do they automatically reset?
Old Jul 22, 2013 | 09:10 PM
Even grease or other debris shouldn't be covering the magnetic encoder. As previously mentioned, the encoder is part of the wheel bearing/hub assembly.
Scanners with the ability to read Honda ABS/SRS codes can clear the trouble code(s). The car does have a self-diagnosis when the ignition is initially turned on and does another self-diagnosis while running. Once a problem has been detected, the trouble code is memorized (in the non-volatile memory) even if the light may go off. If the ABS system is OK, the light should go off.
The memorized trouble codes are not cleared when the battery is disconnected, the ignition switch is turned OFF, or if the system returns to normal.
Old Jul 22, 2013 | 09:14 PM
The wheel bearing with encoder spins when the car is moving, so debris can now be on a different part of the wheel bearing than just where the wheel sensor hole is.
Old Jul 22, 2013 | 09:20 PM
  #17
catkins66's Avatar
thanks... so if I still have the error, I guess something is still wrong. not sure what else to clean it with, but I'll give it another go. do you think I need to replace the wheel sensor again, since I was given that error again?
Old Jul 22, 2013 | 09:23 PM
  #18
catkins66's Avatar
any easy way to clean the bearing, or does it have to be done by pulling the hub?
Old Jul 22, 2013 | 10:37 PM
  #19
It would be a pain to clean. Plus the outside of the bearing does not move. The inside race spins.
Where did you get the replacement part? What was the part number?
Old Jul 23, 2013 | 06:34 AM
  #20
catkins66's Avatar
I got vthye sensor from Auto Parts Direct to You, it's a Dorman 970-028 ABS Sensor and Harness. bad part? I did see the price varied on these quite a bit.
