2003 Accord Engine Wire Harness Problems
Old Dec 1, 2008 | 09:12 PM
joshik
Default RE: 2003 Accord Engine Wire Harness Problems
yeh, maybe i can make it when im there next time. the "temp fix" by the mechanic should hold for a while.
here is the diagram for the 2002 accord ~ #8 is the +terminal cable that goes to the fuse and starter
here is the diagram for the 2003 accord ~E-7
doesnt specifically show a +terminal cable except under "E-7" which im guess is detailed in another diagram which i cannot find. the closest thing i can find is under the parts of "engine wire harness" which is the "sub wire starter" assembly which contains parts called "bolt & nut battery terminal" so i'm thinking that connects to the +terminal of the battery.
what the guy did as a temp fix, i dont see why that cant be a permanent fix if he just cut the terminal off and crimped on a new one. if i put some di-electric grease and shrink tube it, that should keep it from corroding no? im going to have my gf take a pic of the +terminal and the cable that extends from it.
again, thanks so much for everyones imput!!!
blackaccord01
Dec 25, 2014 08:37 AM
Aratyhq
Mar 3, 2013 09:18 PM
understand1
Nov 10, 2012 11:06 AM
hondahead23
Jun 9, 2011 11:00 AM
Accord12404
Feb 23, 2009 12:23 AM
