91 accord transmission problem
Old Jul 6, 2008 | 05:35 PM
jccal22
Default 91 accord transmission problem
Hello, I need help with transmission codes.
91 accord 2.2L A/T. Only hits reverse, second, and third gears. Must shift manually. It won't shift up or down on it's own. "S" light blinks steady will driving. I jumpered the 2 pin connector under the glovebox. I get 2 flashes, pause, 5 flashes, pause, 7 flashes, pause,repeat. I assume this means there are 3 different problems or my controller is shot. Can someone please provide some info? Thanks, Joe
Old Jul 6, 2008 | 05:57 PM
Default RE: 91 accord transmission problem
Code 2: Lock-up clutch does not engage. Cause: Faulty wiring or solenoid valve B
Code 5: Fails to shift other than 2-4, lockup clutch doesn't engage. Cause: Fautly wiring or A/T gear position switch.
Code 7: Fails to shift between 1-4, 2-4, 2-3. Cause: Faulty wiring or solenoid valve A.
I would look at the wiring to the shift solenoid valves to make sure it is ok. In the DIY section, the online manuals thread has sites that have a pdf of a 91 accord shop manual. I know that the spoon honda site has it. This will help you out a lot. The TCU codes are listed on page 9-28. The beginning pages of chapter 9 will show you the location of the shift solenoids on the tranny.
Old Jul 6, 2008 | 06:14 PM
jccal22
Thanks for the fast reply. I'll do some research and see what I can find.
Joe
Old Dec 1, 2008 | 08:52 PM
natloz2
where do i find the diy section?i have the same year accord, same problem, i got a used tcm, problem changed, light was off for 3 miles then back on. at first the car stuck in first gear till 5500rpm then slammed to 3rd. now light flashing and goes 1st 2nd 3rd only.
Old Dec 1, 2008 | 10:16 PM
One the list of forums on the main page, click on the do-it-yourself forum. The online manuals is one of the top posts.
trouble
Aug 21, 2012 07:46 PM
MessAround
Aug 13, 2011 09:45 AM
kellysa111
May 1, 2009 08:35 AM
1999accord_SC
Jun 19, 2007 03:01 PM
huzzsaba
Jan 24, 2007 12:12 AM
