Sponsored by:
Sponsored by:
2003 Accord EX 2.4L Air Fuel Ratio sensor wiring.
Old 09-24-2013, 12:38 PM
mspearin's Avatar
Default 2003 Accord EX 2.4L Air Fuel Ratio sensor wiring.
I have a 2003 Accord 2.4L 4 Cyl. I had a check engine light that said that the Air fuel ratio was bad or had a bad ground. I went under the car and it looks like the wires where pulled out of the plug that goes towards the engine. I have been trying to re-wire it see if it works. I have tried to find out where the 4 wires go. On the sensor there is 4 wires 2 Black, 1 Blue, 1 White. On the that goes to the engine the colors are Red, Red with a Yellow stripe, White with a Black stripe, and a Green. I am trying to put the wires back together but I dont want to short anything out.
Old 09-24-2013, 06:30 PM
Which side "pulled out" the O2 side or the engine side of the harness......also can we assume this is the primary O2 sensor (pre-cat)?
Old 09-24-2013, 09:08 PM
mspearin's Avatar
The O2 Side was pulled out the Black White and Blue wires. Yes it is the one Pre-Cat. I am assuming that it is the primary O2 sensor. According to autozone its a oxygen sensor and an air fuel ratio sensor combined. Around 175$ for a new one. Trying to check and see if this one will work before I order a new one. They didnt have any on hand that I could look at for the wiring.
Old 09-25-2013, 05:12 PM
Are there two blue wires or just one.....so far I've figured out where two of the four go.
The other two, I know the wire color at the ECU/PCM but I'm pretty sure that color doesn't go all the way to the actual O2.
Old 09-26-2013, 12:36 PM
mspearin's Avatar
Sorry for the delay in response. There are 2 Black wires 1 Blue and 1 White. Thanks for the help.
Old 09-26-2013, 04:45 PM
See the attached pic. for the Air Fuel Ratio sensor terminal view.
1: Male - Wht wire goes to Female Red/Yel (Sensor Ground (AFS -))
2: Male - Blu wire goes to Female Red (Sensor Output (AFS +))
3: Male - Blk wire goes to Female Grn (Heater Control (AFSHTC))
4: Male - Blk wire goes to Female Wht/Blk (A/F sensor control)
Attached Thumbnails 2003 Accord EX 2.4L Air Fuel Ratio sensor wiring.-sensor-terminal-view.jpg
mac5155
05-20-2014 12:29 PM
ashkumar76
10-29-2013 05:29 PM
phantomgrey92
05-19-2013 09:01 PM
phibbs87
08-12-2007 08:17 PM
2.2ex965spd
04-20-2007 04:14 AM
Quick Reply: 2003 Accord EX 2.4L Air Fuel Ratio sensor wiring.
