2003 Accord ex-l v6 issues....
Old Jan 9, 2010 | 06:53 PM
micco's Avatar
Red face 2003 Accord ex-l v6 issues....
Hi Everyone,
We have an 03 accord v6 and like the car, but there are some things i don't think are right.
1) sometimes after starting the car there is a slight fuel smell.
2) When the car accelerates hard it smells like rotten eggs
3) fuel mileage is bad, right now getting less then 400km per tank (less then 250miles)
I think all these are related somehow and looking for some guidance on where to start. I was also going to replace plugs, fuel filter and air filter. My local partsource has Bosch, but i have mostly used NGK in my imports. Any suggestions on a good plug for these motors?
Another thing (4), The traction control seems to be noisy - like grinding/abs sounds. Is this considered normal? Our last car with tcs, was quite...
Info would be appreciated.
Thanks all!!!!
Old Jan 10, 2010 | 06:18 PM
Always use NGK spark plugs. Your owner's manual should give you the proper part number.
The rotten eggs smell is indicative of a bad catalytic converter.
I think doing a tune-up to see if the fuel smell goes away. Also, stop by an autozone and have any codes read off of the ECU and post the code(s) on here. They will be a P and four numbers, i.e. P1234.
Old Jan 11, 2010 | 10:22 PM
micco's Avatar
Had it scanned and no codes were returned.
Also had live diagnostic and everything checked out
frankenstein69
Dec 28, 2014 12:36 AM
doistrakh
May 2, 2013 06:44 PM
Ineedhelp
Jan 22, 2012 07:29 PM
GOT BOOST
Nov 2, 2009 08:32 AM
msheehan
Mar 31, 2005 01:18 PM
