2003 Accord key fob
Old Apr 23, 2012 | 03:35 PM
lks's Avatar
lks
Default Speculation
The only way I can conceive that the immolbilizer transmitter could be confused by keys/metal, before the correct key was inserted, was if the immolbilizer transmitter turned on before a key was inserted into the ignition. Like if it turned on when you un-locked and opened and closed your door for a short period. Like your dome light does. Pure speculation, but I don't think the transmitte turns on until at least the first part of the key has been inserted. A wrong key that was up against the ignition key housing, before the correct key was fully inserted, may potentially reflect a stronger signal to the immolbilizer receiver than the not fully inserted correct key. In a perfect system, the immolbilizer transmitter antenna would be so directional that almost all of it's energy would only land on the inserted key. Or the inside of the ignition housing, could be metal coated so no energy extended outside of it. I would be interested, if anybody finds out the the real answere.
Old Apr 23, 2012 | 07:08 PM
What is wrong with your car?
csh217
Jun 17, 2014 05:53 PM
JuiceGeary
Jul 17, 2010 07:16 AM
gobears81
Jun 23, 2010 06:20 PM
toicy4ya
Mar 30, 2010 11:51 AM
christo16
Oct 4, 2009 10:26 AM
